I had people over for Thanksgiving and one of the guest’s kids bumped my motion detector and broke the mounting bracket. Uggghhh.
Can’t find anywhere to buy just the bracket as I would.
You don’t need the mounting bracket.
Do you have it mounted correctly? Unless that child is near 8 feet tall, a child should not be able to “bump it”. It is supposed to be at 7 1/2’- 8’. I don’t even use the mounting bracket. They are designed to be mounted directly to wall/corner btw.
Just mount it to the wall without bracket (only use the screw holes on one side)
It probably has to be mounted higher based on your information. Its in a corner and I guess I can do that without the bracket. Would just be nicer to have one if someone has one to spare
