I am seeing the same strange item in history every day for the last week. Once each day, at the same time. The item reads, “Command: Weather Go Control3 Panel”. Does anyone know what this is about?
Are you seeing this on the panel or in Alarm.com?
In either case, the forecast weather update on your panel screen if you use Gold Interactive service is sent once per day by Alarm.com, which would be what you are referencing.
It is on Alarm.com. Yes, that makes sense, especially as it is at the same time each day. Thanks for the explanation.
Happy to help!
