Hi. My Smoke Detector keeps going off on monitor as Is “Tamper” every 5 mins or so. It’s not tampered and I can not stop the sound. Last time this happend I tried to reset Smoke Detector manually but it set off a real alarm. Can you help stop false Tamper notice.
We cannot manually dismiss a trouble condition on the alarm panel. If your panel reports a tamper for a sensor, the first step to try and resolve would be to remove the sensor from its mounting plate and reconnect it. Make sure it is firmly shut. Does the tamper go away?
If not bring the device closer to the panel, close the tamper switch. Does the tamper go away?
Also, since this is a smoke detector, double check the replace by date on the device label. If it is expired it should be replaced.
