Skybell Remote Connectivity Failures
Hi all,
My Skybell has started dropping out for extended periods of time. Are you able to see any patterns in what it’s communicating back when it is connected? It had been working fine for 12-18 months.
Often when it’s disconnected it also has no blinking light pattern. No changes to the hardwiring of the doorbell, or to the network configuration.
Thanks!
-Michael
Going back as far as 3/13, records indicate low wireless link quality. The device is currently not connected and remote commands are failing. You will want to manually reboot the device and test, has it connected?
How long have you noticed this behavior?
Keep in mind that the Doorbell Camera requires a minimum of 2 Mbps of upload speed in order to operate at the installation point, however for overall sustainability more upload speed is recommended. What is your upload speed at the installation point currently?
