Without using Skybell’s motion trigger, is it possible to create a rule that will save the clip when a door lock is pressed, or door lock is unlocked, or just the door being opened? Thanks.
Yes, you can select the Skybell HD for Lock Activity or Sensor Activity schedules, but the Skybell does not support pre-event buffers for event triggered recordings, so recording would start after the event in this case.
Thanks, Jason. Is there a way to stream the live video from skybell to the ADC app in Amazon Fire devices (TV or stick)?
No, I don’t believe this is possible. Skybell Streaming is through the mobile app as it integrates the Skybell service.
We’ll check with ADC to see if this might be in the works.
