I have a carbon monoxide detector on each floor, and the top floor is giving a fairly consistent supervision lost message at my 2Gig panel. Can I use a repeater in this circumstance to improve the signal?
Unfortunately, the resolution products signal repeater will not improve signals from life safety sensors, only security sensors. If possible, relocating the panel to the second floor and using a TS1 secondary touchpad downstairs may be an option. This of course works best if you already have a keypad on the second floor to switch with.
