Can SAM be enabled for temperature sensors? and if so, how does one do that? thanks.
By SAM do you mean Sensor activity monitoring?
If the temp sensor is programmed as an alarm sensor, no. If programmed as a non-response sensor, yes.
If it is programmed as an alarm sensor instead you can just create an alarm notification which triggers when those sensors are tripped.
