I want to make a rule where if my alarm trips, certain lights go on in the house.
When I create the rule, I select When this even occurs and I select “alarm”
Then it asks me to select a sensor to trigger the alarm to run the automation.
I want it so that if the alarm goes off from any sensor, the rule will run and turn on the lights I have selected.
The only option it gives me aside from the separate devices is “any panic device”
This would exclude motion detectors, window sensors etc. and onlygo if we hit a panic alarm
How do I create a rule that if the alarm is tripped in any way when we are not home that the rule will run? As I recall it used to just say “any device”.
