So for your lights, does “Living Room Sconce” or “Kitchen Nook” work when trying to activate by voice?
Do not say Light at the end. Just the full device name. Any luck on those two specifically?
My new Rachio is set up but the old one is still listed. Can you delete the one numbered 295…?
Your Rachio account is synced to Alarm.com, I cannot delete specific controllers, I can remove the account sync, which will remove all devices.
To clear the old controller, you’ll need to delete it from your Rachio account.
I updated the firmware as directed but the gate still does not show on the panel. Also, giving commands using “Garage” is typically how I talk to Google Assistant. I have one named “Garage” and the other named “Gate” so not sure how to better distinguish them. Any ideas?
Try naming them something arbitrary as a test. I am curious if Google is not handling it as a specific device if you say “Close the Garage” if there are technically two MyQ devices, even with one being a Gate.
I am double checking with Qolsys to determine if the gate should be supported or if there is a reason it would be missing from the panel when the garage is there.
If the specific lights I mentioned and arbitrary name change for the Garage doesn’t work, check your recent commands in the account settings of your Google Home app. Did Google register the correct thing you said?
