Questions on Rachio, gate, Google Assistant
I’ve cleared the old Rachio device for you from the account. You can sync up your new one via the same process in the Irrigation card on the app home page.
My new Rachio is set up but the old one is still listed. Can you delete the one numbered 295…?
Can you try updating to the latest firmware per instruction here? Any change?
I updated the firmware as directed but the gate still does not show on the panel. Also, giving commands using “Garage” is typically how I talk to Google Assistant. I have one named “Garage” and the other named “Gate” so not sure how to better distinguish them. Any ideas?
I see a lot of lighting devices with “Lights” as the last word in the name. That will likely cause an issue per the ADC notes.
Ok, I renamed all of the lighting devices so that “lights” is no longer in the name. Still having the same problem.
