Today I armed my IQ Panel 4 with the DSC arming keypad, exited to the garage through a door programmed with long delay, opened the garage overhead door fitted with a Qolsys tilt sensor programmed with long delay, exited the garage and closed the garage door and noted an alarm sounding which was confirmed by a call from the monitoring center. This was all within the period of the long exit delay. According to the notifications I got from Alarm.com, it seems the overhead door tilt sensor caused the alarm despite being programmed with long delay. I got the attached email about the alarm which doesn’t make sense to me because I don’t have a mPERS sensor or fall detector. Could you please explain to me what you think happened? Is this a bug? Thanks
I would go in and check the settings for that sensor
This would generally be the result of a sensor programming issue.
The timing of the alarm is normal. It occurred after 60 seconds after arming, the exit delay on the system is 60 seconds per your panel configuration reported to ADC.
Right now I am not seeing any outward issue with that zone programming, but ADC is reporting that data was uploaded from the panel last night, I wouldn’t be able to see the issue if changes were made. Did you make changes to the sensor programming since this occurred?
No, not to those sensors. Last night I only added an additional keypad to th system.
Monday, 29 November 2021, 06:35AM -08:00 from Jason via Surety Support Forum notification@support.suretyhome.com:
The other thing is that you say that the exit delay is reported as 60 seconds, but the exit door to the garage and for and the tilt sensor are programmed to be long exit delay at 120 seconds. I double checked that just now on the panel.
Right, I’m saying it occurred after the normal exit delay, suggesting the zone is not being treated as the zone type you mention, which would typically suggest a programming mismatch somewhere. Can you send me a screenshot of that sensor programming on your panel via private message just to be sure it matches what I see in ADC?
If you place your account on test mode through our System Manager then try arming and opening that zone again between 60 and 120 seconds from the arming, do you see the same issue?
If you then arm, wait longer than 120 seconds, then open the door, does it function as expected?
How do I send a private message? (I’m new to Surety and haven’t done that yet)
You can use the Private Message Surety button in the top banner, or you can just send one by clicking on my name here and then select message.
I sent the private message with the screenshots. If I arm away the laundry room door to garage gives me 60 seconds only to exit to garage. After 60 sec. if I open the laundry room door entry delay becomes active and I have to disarm or alarm sounds after 90 sec. Opening the garage overhead door during the exit delay of 60 sec. extends the delay to 120 sec. counting from when the system was armed, not from when the garage overhead door was opened. Not sure if it makes any difference but I’m arming the system through a ws9lcdwf9 keypad.
OK, thank you, I believe I see the issue. It looks like it is not anything in the panel, but rather how Alarm.com has those sensors categorized. Currently they are listed with a device type of “Orientation” which seems to be assumed as a fall sensor, and I am not able to edit it. Looks like a default assumption made in the software based on programming from that panel.
I will have Alarm.com address this on our end. It should not require additional troubleshooting or any changes on your end, but I will follow up here with any additional info and confirmation.
Ok, thanks, that resolves the sensor type issue. What do you think about the laundry room door being programmed for long delay but giving only 60 seconds to exit? Also I’m still not sure what caused the alarm that day… was it the supposed “impending fall” or was it a problem with an incorrectly short delay period?
The panel is armed with a default 60 second exit delay. The “Long Exit Delay” extends the time for exiting and closing up that entry zone, but the sensor must be opened within the 60 seconds or else the panel will simply be in an armed state already.
It looks like the first door was opened just after the 60 second exit countdown ended, or was not yet closed by that time, and the second door, the “impending fall” that was incorrectly labeled, is the alarm event. There is clearly a bug in this case with how the tilt sensors are reporting. I do not see any reason the tilt sensor should have reported that way, and I see it referenced as a “fall” event when it opens in other areas of your history.
I am working with ADC on this to determine the ultimate cause. This may require changes on their part or in Qolsys firmware.
Can you confirm the exact model number of the tilt sensor? Is it a QS1121? QS1131?
Also can you confirm whether the same issue occurs on the other garage tilt sensor? Can you test opening that other tilt sensor while armed?
The tilt sensors are model QS1131-840
Thank you very much. I spoke with Qolsys yesterday and they are investigating this. Looks like a bug with either that model or with Tilts and long delay sensor group.
To confirm, when you open the garage door when the system is armed, you immediately hear the siren, right?
If you change the group to normal entry delay (group 10) does the same thing happen?
When I open the garage door there is a delay of about 100 seconds before the siren sounds. When I change the delay from long delay to normal delay the siren sounds after about 30 seconds. So there is no problem with the delay programming on the tilt sensors. However, when I exit the laundry room door to the garage, even though that door is programmed with long exit delay the system arms after only 60 seconds and does not give the 120 seconds of the long delay. Of I open the garage door within the 60 seconds then the delay is extended to 120 seconds total. I think what happened the day of the alarm was I didn’t open the garage door within the 60 seconds given by the laundry room door because I had programmed it for 120 seconds. I opened it to exit the garage in the car after the 60 seconds and that caused the alarm. So the problem is the laundry room door not giving 120 seconds. I deleted the sensor and reinstalled it again with the long delay but the system still arms after 60 seconds. Do I not get it?? Or what is the problem? Thanks for your help with this.
I have been trying to recreate this on my own system, but I have not been able to.
I apologize but I misspoke before, a bit turned around based on the description of this error.
What you are seeing with the garage door extending the time is normal, but the result of a different setting I would expect. The Auto-Exit Delay Extension setting.
With Long Exit Delay, you should just be seeing 120 seconds as the exit delay if you have any sensor group 12 sensors.
If you open just that Laundry room door twice during the countdown does the time extend by 60 seconds?
I am trying to see if Qolsys knows the potential cause here, or recreate a combination of settings that causes this, but it seems like it is a bug. Combined with the mPers reporting, something is definitely off. I have uploaded panel logs to Qolsys so they can do a deeper review of what is going on.
have u tried changing the exit delay to 120 and see if then it restarts it when u open the garage door so it will then give u more time
