Qolsys Panel 2+ External Siren
Other than just wiring it up is something needed to be done on the Panel.
The pairing steps in the prior response are what must be done at the panel. If the Hardwire translator is not itself learned in on a unique zone (not just the hardwired sensors attached) you cannot use wireless siren activation and reset smokes.
There shouldn’t be anything else you need though, so double check your wiring. Note that the + - terminals on the terminal section labeled siren do nothing if you are activating wirelessly.
Like the panel itself the siren out is not energized naturally. You need to pass power through it as a relay.
Connect an AUX terminal to “IN” with a jumper.
“OUT” to the + siren lead, GND to the negative siren lead.
See the image attached. It would need to be wired exactly as shown.
