Qolsys Image Sensor - Sensitivity Settings
In the installation manual for the Qolsys PIR Image Sensor, it indicates that the sensitivity is normal by default, but that it can be changed. However, when I navigate to the System Tests/Image Sensor Configuration/View section (IQ panel), there is no option to change the PIR sensitivity. Any thoughts? Thanks.
Les
As of the current time, unfortunately Qolsys has not provided control of that setting at the panel. It can be done remotely, but only by the dealer. If you need to adjust your IS sensitivity to high or low on a Qolsys panel, let us know and we would be happy to help. You can make any request using our secure message tool.
Thanks. I appreciate the quick response.
