Apologies for the lengthy first post… I’ve been reading this forum (and one other where I will cross-post this) pretty much nonstop for the last couple of weeks, and have found it immensely helpful in planning out a DIY security system design. The people and resources I’ve found to be able to do something like this myself are pretty amazing in an industry that is traditionally very closed off and secretive to everyone but installers.
I’m getting ready to order a system for a newly remodeled home in the next couple of days. I didn’t have the foresight to install wiring for hardwired sensors, so I am pretty well limited to a wireless setup. I’ve changed my mind back and forth several times between 2GIG and Qolsys, and I think have finally settled on the 2GIG.
I like the aesthetics and much of the functionality of the Qolsys control panel better, as well as the fact that is brand new and far from EOL, but the fact that there are no “real” secondary key panels or touchscreens is a dealbreaker for me. (Yes, I am aware of the IQ2, but what amounts to an iPad sitting on a cheesy stand on a dresser or even worse velcroed to a wall, both with a power cord hanging out of the side, does not feel like a “finished” installation to me). How hard would it have been to create a dumbed down version of the IQ Touch to act as a secondary panel that actually felt like an installed panel?
Appreciate any input anyone has on their decision to go with 2GIG vs Qolsys, and also answers to the below few questions regarding the 2GIG system:
I’m sure I’m beating a dead horse here, but does anyone have any idea on timing of the GC3 panel? I’ve ready Q4 2104, Q1 2015, etc. but obviously it has not happened yet. Is there any assurance that it will be available to the public and not just to the big contract provider?
Does anyone know if there will be a “TS2” or if the TS1 will be software updatable to be compatible with the GC3 panel when it is released?
On the current 2GIG models, is it possible to set a motion sensor as a perimeter sensor or some other type of sensor that will be active in “Stay” mode. Assume a two story home with a walkout basement, and the desire to have the motion sensors in the basement active during “Arm Stay” mode.
Are glassbreak sensors considered interior sensors, or perimiter sensors for the purposes of arming the system? Or can they be programmed to either?
Any disadvantage to the Honeywell glassbreaks that are smaller and better looking than the big 2GIG ones?
Is it possibly to arm and bypass zones from the TS1? The user manual indicates zones can only be bypassed from the control panel, not sure if this extends to the TS1 or not.
If you arm the system and auto bypass a zone (an open bedroom window for example), are you able to open and close that same window as much as you want until the alarm is armed/disarmed and the bypass state is reset, or will it reset and become active once it detects that the window has been closed?
Is it possible to manually bypass a zone and have it stay bypassed (even through arming and disarming cycles) until you manually un-bypass it?
Assume you are armed in away mode, and enter your home through an entry-delay door… If you pass through a regular motion sensor protected area during the entry delay but before disarming the system, will it trigger an alarm immediately? If so, is there a way to ignore anything but the first alarm trigger? (IE, walking in through main delay entry door, passing by a hallway motion sensor on the way to put down groceries without setting off the system, returning back to panel to disarm before delay expires)
Is the z-wave control capable of flashing/blinking a controlled light fixture on a specific trigger (alarm activation during night hours for example), or is it only capable of toggling them on and leaving them on for a set period of time?
What experience has anyone had with ionDigital Micra and Plunger style wireless door and window contacts? Reception, battery life, etc.? I’m limited in a few locations on the depth I can drill into a frame, and these seem a great solution. I’d like to standardize the same type of sensor everywhere, even in locations where I do have more depth, so I want to make sure they are as good as the OEM sensors.
Another Micra/Plunger question:… If installing on a sliding door where the latch has ¼ inch of play (door will wiggle open and shut ¼”)… will that be enough to trip the sensor? How far roughly is the throw on the plunger before it trips, or the distance the magnet on the micra would have to be pulled away before it trips?
Any experiences good or bad with the firefighter module? I have hardwired smoke and C02 detectors which I don't want to replace, but would like to trigger the alarm when they go off.
Thanks so much!!
