I’m somewhat stuck with the Qolsys panel pairing of the D/W Mini sensors. The panel is adding the sensors (5 so far), but when I try them (open/close a window), nothing happens. I’ve tried running a Sensor Test, but under “Result” all I get is “No Signal”.
I’ve tried rebooting the panel twice already. I powered down and disconnected the battery and the transformer. Nothing changed! When I tampered with the sensor at the front door, the panel did say “Front Door Open”, but when I tried to repeat it by opening the door, nothing happened. Now the panel says that sensor is Open and won’t let me arm the system.
Anyone has any ideas? The sensors I’m trying to pair are all QS1115-840, if that helps.
Under System PIC, I see V80_05. Under RF PIC Version, I see 8.2-G.
Does that guve you what you need?
Can I contact Qolsys technical support, or are dealers only allowed?
Once I figure this out, I’ll be able to call in and set up monitoring with Suretycam, but I’m stuck until I resolve this. I saw in an earlier post you service Atlanta, so one least thing to ask!
Once I figure this out, I’ll be able to call in and set up monitoring with Suretycam...
This page may be of use in determining what service you’d like. Once you know whether you’d prefer Basic or Gold Interactive, purchase the selected service; no calls are needed. You will be asked for the information we need to set up your accounts as part of the check out process.
Our FAQs might answer some questions for you. All of our support is done online. For any technical questions, you’re already in the right spot. For all other questions, you can email customerservice@suretyDIY.com .
