I have an older MyQ Gateway which I have paired with my Alarm.com account. I have successfully added 1 of 2 garage doors. The second garage door will not add. When I go thru the process, its like the opener never receives the signal. Both openers are the exact same and both worked with the MyQ app prior to this. Can you assist me?
Assurelink gateways were not supported in the past, but it looks like you did register this one through ADC successfully. I hadn’t heard a change in compatibility but we can troubleshoot.
When you go to add another garage door through the Alarm.com website, what does the status LED on the gateway do?
Just to be sure, there are some steps in the online process which are just informational, and you must click continue to actually perform the step. At times I have seen someone get stuck there.
