I added a sensor (sensor #42 in my system) and it shows up in the sensor list. It also is checked for a “monitored sensor”
I want to set up a notification where if that sensor opens, I am notified. When I go to the notification section at ADC and try to select that sensor, it does not appear in the list.
In fact only a fraction of my sensors appear in that list.
Why are not all my sensors showing up in the list to chose from?
So you are saying the door window contacts are entry/exit or perimeter type zones that show up under the sensor tab where they can be selected for “activity Monitoring”, but are not showing as a selectable device under notification for Rules?
What Rule?
If they were not showing under sensor tab, I would suggest you perform a cell test (if the sensors were just recently added)
also, you will need to contact central station so they can add the new zones and descriptors.
is it selectable for any? I just want to be notified when this gate is opened, but I dont want the alarm to go off due to service people coming in and out at random times.
As far as I can tell you have everything set up correctly but I see a discrepancy in the settings on Alarm.com’s end. We’ll have to work with ADC on this and they aren’t open until tomorrow so hang tight and we’ll let you know what we find then.
I would like to mention also, that when I set my sensor to zone type 23, it initially did not show up as a selectable option in any of the suggestion type rules, then it did, but in only some (it for example, was not a selectable option in “fridge left open”, but was in the ones previously posted above).
In general when adding sensors and selecting sensor activity monitoring for them, there will be a delay as to when they are available for selection in activity monitoring notifications.
The delay should be no more than 20 minutes or so. Logging out of your account and logging back in is often required to actually view the change.
