New install camera questions…
I am looking at doing a iq5 hub install and gathering as much intel before placing the order. In regards to the Indoor AI Camera Mini V516 I have a few questions.
The cameras are WiFi dependent likely for large data upload requirements no doubt. In a situation where WiFi is offline all camera functions are offline, since there is no cellular backup ability like the qolsys panels. The cameras are direct to alarm.com.
-hypothetical: (video monitoring, without camera pro service)
I have an alarm trigger (WiFi failed) The backup cellular would still go thru. We are unreachable to cancel or confirm. Alarm.com in this case would try to view camera footage to verify. In this scenario, since the WiFi is down they would not be able to view anything, correct? They would just dispatch police fire etc.?
-I see a dedicated 2.4ghz network is recommended for best operation. We have an Eero router which has 2.5/5ghz under 1 network name. You can’t separate them. Has anyone had issues connecting Indoor AI Camera Mini V516 cameras is this situation?
-I am aware that for difficult devices I can temporarily disable my 5ghz to pair the 2.4ghz only devices. Just curious if anyone has had connection issues when the WiFi hiccups. We currently have nest cams that seem to do fine.
Just to clarify, Alarm.com does not monitor the video feeds.
If you have video verification enabled on your plan and an alarm signal comes in from your alarm panel, our professional monitoring operators would attempt to view cameras you have selected for that feature as verification.
If they cannot view video, they will continue with call procedure which can vary based on location, but in general they would call your contacts listed prior to dispatch, then dispatch.
We have had users report issues with Eero routers in the past due to limitations on network setup.
That said, it has been a while since I have heard any reports of Eero issues specifically. Most reports were from a few years ago and the underlying issues may have been improved through updates.
One thing that can happen is a device shuffles between access point nodes, which can cause temporary disconnects. If you do encounter issues with connectivity, I would recommend a separate access point which can be configured to 2.4Ghz only for your Alarm.com devices to keep them separate.
Jason,
Thank you for the reply and information! Much appreciated! Sounds like I have all the info I need for an order.
Best Regards,
Chris
