Hi all,
I’m switching from an unmonitored Vivint Sky Control system and plan to go with Surety for professional monitoring. Before I order hardware, I’d like to confirm a few things.
MY SETUP
3 doors, 15 windows, (possibly 1 overhead garage door - currently setup under MyQ)
Houston area, TX
Keeping my Google Nest cameras separate for now
Plan to add wired PoE cameras down the road
PLANNED PARTS LIST
Qolsys IQ Panel 4, 345 MHz, PowerG kit with LTE (10 door/window sensors + 1 motion)
About our service, we are a do it yourself Alarm.com service provider. All service and support is handled online through our website. We are unable to provide phone support, local installation, or maintenance. You can find more about how Surety works here.
Service through Surety requires an Alarm.com compatible panel as well as an unregistered 4G LTE cellular module.
Going through your questions:
The IQ Panel 4 has been discontinued by the manufacturer and replaced by the IQ Panel 5, so if you’re purchasing a new panel, you’ll want the IQ Panel 5 instead. It works natively with PowerG, and you can add the 345MHz IQ Card (the Legacy Radio Card option on the product page) to use 345MHz sensors. The PG9303 contacts are compatible with the IQ Panel 5. For the garage, there isn’t a PowerG tilt sensor. If you want it on PowerG, you can put a wired contact on the garage door and connect it to a PowerG sensor with an auxiliary input, like the PowerG+ D/W Contact With Auxiliary Input.
We recommend Verizon for its generally wider coverage, but it’s worth checking the AT&T and Verizon coverage maps for your address. You can choose either carrier when ordering the IQ Panel 5.
Unfortunately, Google ended support for conversational actions for Google Home and Google Assistant, which ended Alarm.com’s support of voice commands through Google Assistant and Google Home devices. Siri or Alexa can be used for voice control of your Alarm.com system instead. More info here.
It depends on the model numbers. Standard 2GIG sensors like the DW10, DW20R, and PIR1-345 can be used with the 345MHz IQ Card. Vivint also used proprietary models like the DW11, DW21R, and PIR2-345, and those can’t be reused. If you post the model numbers from a few of your sensors, we can confirm which ones will carry over.
Alarm.com cameras are included in Surety Protect and Surety Complete. The MyQ add-on is available on Surety Home and Surety Complete, so Surety Complete is the plan that includes cameras and also offers the MyQ add-on. You can upgrade at any time, and you’ll only be charged the prorated difference for that month.
Yes. You can cancel anytime without penalty using the Cancel Service button in your Account Dashboard under Alarm Subscriptions. We can’t refund or prorate a month once it’s started.
Plan pricing and features can be found here. As service is offered on a month to month basis, plans can be changed at any time. To begin service, purchase the service plan that best suits your needs. After purchase, the website will walk you through the account creation process. Provided you have an unregistered, 4G LTE module, it takes about 5 minutes from service plan purchase to account setup and connection.
