Just received a new NanoMax to replace a GE to try to cure an intermittent operation issue. However still having issues about 45 feet from panel. Wood door. Thanks
What sort of intermittent operation do you mean?
Does the sensor report loss of supervision? Does it not register open when it opens? Does it register open when it shouldn’t?
Is the door frame metal? Can you post a quick image of the sensor where it is installed?
