I would like to provide lock access to about 50 different users, each with a unique code so that I can track their access history. These users do NOT need security panel access. I see that the Yale Touchscreen Z-Wave Lever Lock allows up to 250 users, but the 2gig panel only has up to 32 user codes. Will I be able to assign 50 different lock access codes using the alarm.com portal? Or will the 2gig panel impose a limitation of 32 lock access codes?
Yes, you can have additional user codes for the lock beyond the limit allowed by 2GIG. However, you can only give panel access to a number of users up to the 2GIG limitation. These codes can be created through Alarm.com.
