Low Battery - Image Sensor
I just received a low battery notification for an image sensor I purchased less than 2 months ago. That doesn’t seem normal at all? Should I return the sensor?
Double check the date on the batteries. We do show one of the 3 image sensors showing lower than normal power. What is the date on that battery? It could have been packaged with an older battery from the manufacturer.
Have you tried replacing that battery and do you see the same result?
Make sure to only use lithium batteries when replacing the original batteries.
