good day,
i just changed the batteries. the lock still not working and not showing connection
please help. thank you
good day,
Happy to assist!
I have sent some commands to re-sync Z-Wave devices and the lock is no longer reporting low battery. Are you able to confirm? You may need to log out of Alarm.com, then back in, to see this change.
Are you able to lock/unlock locally with a code?
If the lock works locally, can you try:
yes! perfect. thank you!
