I have a bunch of linear switches but its been a while since I have installed them… I have a new one which I am putting in my garage but I have two existing switches, wired 3-way with a traveler wire. Can I use the linear (WS15z5-1) switch and keep the other existing 3 way switch or do I have to get the WT00Z-1 to still have 2 switches in the garage?
Happy to help! You cannot use standard switches in a 3-Way configuration with the Linear WS15z5-1. To make a 3 way switch, the WT00Z-1 would be needed at the other switch location.
I’m not aware of any that are officially compatible with Alarm.com and compatible panels.
There’s at least one that says it will work with dumb switches if a neutral wire is available. (Inovelli is the maker) I could not confirm whether this would work with the panel though.
