trying to connect a yale real living lock to a 2gig panel purchased from suretydiy
range in which the lock operates is quite short
tried using aeon extender and a regular z-wave outlet
i also tried a z-wave outlet instead of that repeater just to make sure
I did follow instructions for adding lock to z-wave network, i.e. join in close range, then move to final destination, then relearn network.
The lock will not work beyond 20 feet or so.
Do you know whether having the 900 mhz module in it affects z-wave range?
