IQSmoke False Alarm
Just installed a new IQSmoke. Seemed fine, but about 15 minutes later the panel reported an alarm from the smoke detector. Surety central station called and I waived them off (thanks guys). But, the sensor still showed as active on the panel so I took it down and removed the batteries to prevent another false alarm. The detector itself never alarmed - just the normal intermittent green blink. Defective detector or something else I can do?
Update: I installed a new CO detector at the same time and 30 minutes later it did the same thing! This makes me think I’m doing something wrong but I can’t understand what.
Update 2: After another 30 minutes or so the panel reported a smoke alert again! The detector had no batteries in it at the time so whatever happened it happened independent of the detector. After talking to central station for a third time, I deleted both the new sensors from the panel. Not sure where to go from here.
It looks like those devices have (understandably) been removed from your system.
The smoke and CO detectors you purchased are Qolsys 319.5 MHz but your panel uses 345 MHz (2GIG/Honeywell). I suspect that when you added them to your panel it was actually a neighbor’s 345 MHz door sensors that got added because 319.5 MHz sensors would not work with your panel.
They’ll need to be returned and 345 MHz detectors purchased instead.
Thanks Ryan. Can you help me initiate an exchange or do I need to contact sales?
Thanks,
Ben
We’ll initiate it but the returns department won’t be in until Monday. We’ll reach out then. Sorry for the confusion and unpleasant morning!
Thanks Ryan, Monday is fine. My fault for not paying closer attention to what I was ordering.
