IQ Remote Tablet Low Battery Alerts
Qolsys IQ remote tablet s/n qw04A210505948 purchased in 2022 from Surety Home keeps sending me alert emails all day long a low battery and then fully charged and about an hour later another low battery alert (repeat). Am I able to open up the IQ remote and replace the battery or is this remote shot?
Happy to help!
We can see that you are using the IQ Remote QW9104-840, which has an internal rechargeable battery. However, Qolsys does not offer the battery as a separate replacement part. You may be able to find a suitable replacement battery online but we cannot guarantee that it will not cause issues since the device is not designed for routine battery replacement by the user.
Before considering a IQ Remote replacement, we recommend checking that the remote is firmly connected to its original power adapter and that the outlet is functioning properly. If possible, you may also try a different working outlet to see whether the alerts continue.
If the issue persists, the internal battery or charging circuitry may be failing. Since your remote was purchased in 2022, it would be worth considering whether the device itself needs replacement.
Please let us know whether the low-battery alerts continue after checking the power connection and outlet, and we’ll be happy to help determine the next steps.
Thank you!
It is firmly connected to its original power adapter and has been working for years with no issues. The power outlet works 120V steady power with no issues both receptacles. Have never had to unplug it from AC Power. I powered down and up the unit and that did not do anything. The alerts keep on coming. Is it possible the power adapter is bad? Should I swap out the power adapters with the main control unit and see what happens?
We recommend first reseating the original power adapter of your IQ Remote QW9104-840 by unplugging it from the AC outlet and plugging it back in or you can try a different, known-working AC Power outlet to test. We don’t recommend testing another adapter from another device since it may not be compatible and could further damage your IQ Remote QW9104-840. I will further check the adapter specs of your IQ Panel 4 and IQ Remote QW9104-840 if they are compatible for swapping and will update you once I have additional information.
Thank You!
We see that the IQ Panel 4 and IQ Remote QW9104-840 use the same power adapter specifications: 7 V DC, 1 A. However, we’d like to verify the specifications of your actual adapters before recommending that you swap them to help prevent any potential damage. Could you please send us a photo of each adapter’s label so we can confirm the specifications?
Thank you!
