I have been trying to setup a new system for about a month now. I am not at the location of the system full time so every time I hit a roadblock it could be several days or more before I can try again.
My first failed attempt I attributed to a bad wifi connection. The property I am setting this up at is under construction and I didn’t have internet installed there yet, so I tried using a connection I have from a nearby building. When the panel failed the dual path wifi test and seemed to have difficulty maintaining a wifi connection, I assumed I was just too far away from the AP and it couldn’t maintain a stable connection. I gave up until I could install internet at the property.
Now that I have internet at the property I tried again. The new wifi AP is literally 10 feet from the panel. I can connect to it from other devices anywhere on the property. I tried to run through the setup wizard and again the panel would not connect to wifi. Quitting out of the wizard and going directly to the wifi page it sees the connection, allows me to enter the password, says connecting, and then says ‘saved’ but is not connected.
Given that IoT devices can be quirky about wifi things, I thought maybe it was because the SSID had a space in the name. So, I changed the SSID to use underscores instead of spaces. Still no-go.
Then I remembered I was using a wifi 7 AP broadcasting on 2.5, 5, and 6 GHz. I know this can trip up IoT devices as well, so first I tried disabling the 6 GHz band. No dice. Then I tried disabling 5 Ghz band so now the SSID was only operating on 2.4 GHz. Still no dice.
I’ve tried deleting the wifi entries in the panel multiple times, rebooting the panel multiple times. I’m not sure what to do at this point. I’m starting to suspect a bad panel.
