IQ Panel 4 will not clear door lock low battery alert
The battery on my Kwikset SmartCode door lock got low and caused a low battery alert. After I replaced the batteries the battery status from the lock updated to reflect 100% battery level. Even though the IQ Panel4 sees that the battery is at 100%, it continues to show a low battery alert for the lock and refuses to clear that warning. I have tried the following:
  1. Acknowledged and cleared the message alert.
  2. Locked and unlocked the door to have to lock push pout status updates.
  3. Hit refresh on the lock which always updates to show 100% battery and correct locked or unlocked status.
  4. Cleared the Zwave lock from Zwave devices and then re-added the Zwave lock again.
  5. Removed the door lock battery for over 20 minutes and then put battery back in.
  6. Reran the System test suite countless times throughout the above procedures.
The panel simply refuses to remove this old low battery alert from the lock. On the screen saver screen in the lower right corner I have an annoying red exclamation with a “Needs Attention” message that will not go away. Pressing on that goes to the System Check Results page with a red exclamation by Sensors which corrulate to the door lock low battery warning. Running a new system check does not clear this low battery status even though viewing the door lock device directly shows 100% battery.
This seems like a bug in the IQ Panel 4 firmware. Is there any way to clear this false sensor status error from the panel?
Thanks
Happy to help!
Thanks for providing us all those details. Based on the results, the Kwikset lock itself appears to be communicating normally and is correctly reporting the new battery level at 100%.
We also confirmed that your IQ Panel 4 is already running firmware version 4.6.2, so there is no firmware update we would recommend at this time.
Given that you’ve already acknowledged the alert, triggered the lock, refreshed its status, removed and re-added the Z-Wave lock, removed the batteries for more than 20 minutes, and rerun the System Test, this may be a stale trouble status remaining on the panel rather than an actual low-battery condition.
As a next step, we recommend rebooting the IQ Panel 4:
Settings → Advanced Settings → enter your installer/master code → Panel Reboot → OK
Once the panel has completely restarted and reconnects, please give it a few minutes and then check the System Check status again.
If the red “Needs Attention” indicator and low-battery warning remain after the panel reboot, please let us know.
Hi Brian,
I rebooted the panel and the low battery status still remains even though the actual device status shows 100% battery. Is it possible that the Kwikset SmartCode lock is still sending a low battery alert via Zwave even though it is also sending the updated battery level at 100%. Do you have a way to see status information being sent by the SmartCode lock on your end?
Thanks
Hi, looking at your account, I do not see a low battery for the Z-wave lock.
However, there is a low battery status for a door sensor which shares the same name as the lock.
Changing the battery on your door sensor will clear this trouble condition. When swapping the battery in the sensor, leave it powered off for 60 seconds to ensure all residual charge is drained so that it can resolve the status.
OMG, thank you Jason! I have a Honeywell 5800C2W that converts hardwire to wireless on several doors and windows including the front door. The 5800C2W has a backup battery but trouble for battery and tamper are only reported from the first hardwire device which happens to be the front door. Part of the confusion is that I unwittingly named both the front door sensor and the front door lock “Front Door”. Further adding to the confusion my front door lock batteries just happened to be low when this warning flag came up.
I’m going to rename the front door lock to be “Front Door Lock” so I don’t make the same stupid mistake in the future.
Thanks again for your always excellent support! You guys are the best!
Roger
