I am setting up my IQ2 for the first time and I have 2 hardwire 16 devices to take over all my existing wired devices. Am I able to connect 5 different motion detectors all on different zones? If so, how do I do it? Thanks!
It looks like you are using the Hardwire 16 F correct?
You can connect motions to it, yes that is correct. From the manual:
- Wire all hardwired sensors into the terminals marked Zone 1-15. Zone 16 is reserved
for two-wire smoke detectors:
a. All zones must have a 4.7k resistor (included) installed in either the N/O
(parallel) or N/C (series) position
b. Wire the positive and negative leads from powered devices, such as motion
sensors and glass break detectors, into the “AUX” (+) and “GND” (-) terminals to
power the devices.
Thanks for the response, Tyler.
Yes, I am using the Hardwire 16F, but I wasn’t sure how to connect 5 motions. Can I connect more than 1 motion detector into each AUX/GND terminal? I am just using the basic Honeywell motions (IS 3035 PIR).
Yes multiple powered sensors can be added to the Aux and GND terminals.
This video here is decent walktrhough as well.
