I just purchased two IQ Pin Pads for my IQ panel. My intention was to first have a visual indicator on the wall to flash if the system is armed. This way if kids go to the door in the morning they would notice if the system is armed.
The pad seams to work but I don’t see any lights flashing when it is armed. Is it possible to have the light flash when armed? If this is not possible, any ideas to create something like this? Really looking for something small like the pin pad to show arm status.
Also it looks like I can only have one pin per key pad. Is it not possible to have all user pins work with this keypad?
No, the Pin Pad is best described as a keyfob that requires a code. It does not provide feedback, and it does not accept codes programmed into the IQ panel.
In general, I would recommend going with the dedicated secondary panel (IQ2 in this case). The IQ panel does not have a programmable output terminal, and in general, rigging something to show status will end up being more costly than a secondary panel.
Ok I originally purchased the IQ2 for this very reason but was disappointed that it did not have a wall mount kit (only velcro pad) or a way to hard wire (I am ok snaking the wall if needed). Any thoughts on a clean wall mount solution for the IQ2? Also is it possible to keep the screen on all the time to see arm status? I don’t recall playing with those settings but would be helpful to keep on most of the time.
The difficulty lies in the power adapter, as it really should not be lengthened, so mounting above a receptacle is necessary, and it plugs in on the side like a standard tablet.
It can be done, but it requires a little planning and the IQ2 cannot effectively replace existing older wired keypads in their locations.
As of the last software version, the sleep settings max at 30 minutes through the IQ2 settings.
Ok going to look at one of those outlets with a USB port and see if it can be recessed into the wall. Any good tablet mounts recommended to attach to the wall vs. the velcro pad? I see universal options but would rather go with something that has worked for someone else. It would be great to have something with a bezel to cover up the USB power connection.
Most universal mounts will be more of bracket style than having a full bezel to hide the wire. I haven’t used one myself, but the ones with Bezels that I am finding through an Amazon search are a bit pricey for the application.
I’ve asked Qolsys if they have a suggested option.
Not a lot of affordable options as far as I can find. Have you been able to find something that covers the power cord? Qolsys suggestions were more of the universal bracket variety.
