Improve Performance of Alarm.com Apple TV App Camera Feeds
Hello all, I have a 9 ADC-V521IR cameras on my alarm.com account and a giga plan through Cox for internet. I use the Apple TV Alarm.com app frequently to see the camera feeds, but they either time out or give me an “Unable to connect…” error pretty often. Perhaps i need to purchase the ADC camera gateway, but before spending money I wanted to see if anyone had recommendations on settings etc. I do know that a “direct” connection should be the most reliable, but it is difficult to determine if i am getting that or not.
Any assistance would be appreciated. Thanks!
Happy to help!
Before purchasing an Alarm.com Smart Gateway, we’d recommend checking a few settings that may help improve live video streaming through your Apple TV.
First, please make sure your Apple TV and cameras are connected to the same local network.
  1. Log in to your Alarm.com account.
  2. Navigate to Video > Settings.
  3. Select a camera from the Video Device dropdown menu.
  4. Click Live Video.
  5. Look for the Speed up remote connection initiation setting and disable it.
  6. Click Save.
Please repeat these steps for each camera you want to view through your Apple TV.
Since you are also getting an “Unable to Connect” error aside from the “Time Out” notification, please let us know if you continue to get the same error so we can proceed on the next appropriate steps.
Thank you!
Hi Brian, thanks for the quick response. I had googled that setting and toggled it off a few months ago on all of the cameras. I did just double-check and all 9 cameras still have it toggled off so that is not driving the errors. Definitely up to continue working through other recommendations. Thanks!
And I should have added that all the cameras and each of the Apple TVs are on the same LAN. All cameras are set up wirelessly and the the Apple TVs are set up either wirelessly or wired depending on the room.
Hello Zach,
Thanks for confirming those settings and network details!
Since the speed up remote connection is already disabled on all nine cameras and your Apple TVs and cameras are on the same local network, let’s narrow down whether the issue is specific to certain cameras or your Apple TVs.
Could you please let us know the following?
  1. Do the feeds “time out” or display the “Unable to connect” error on all nine cameras, or does this happen only with certain cameras?
  2. If the issue occurs with only certain cameras, what are the models of these cameras?
  3. What is the current firmware version of your Apple TVs?
These details will help us determine the next troubleshooting steps.
Thanks for working through this with us!
All nine cameras have “timed out” or been “unable to connect” at different times. All cameras are the same model (ADC-V521IR) and all Apple Tvs are 3rd generation Apple TV 4Ks running TVOS 27.0. Thanks!
Hello Zach,
Thanks for the additional information!
We will escalate this case to Alarm.com for further investigation. At this time, we cannot provide an exact turnaround time for their response, as this will depend on their investigation and the complexity of the issue. However, we will keep you updated as soon as we receive additional information from them.
Hello Zach,
We have received an update from Alarm.com on Case# 06796941:
As per Alarm.com:
A Smart Gateway likely isn’t the first fix I’d try here, since the more likely causes are LAN (local area network) path concerns between the Apple TVs and cameras, or how the network is handling WebRTC traffic.
The “Unable to connect” message in the Apple TV app indicates that WebRTC is falling back because a direct connection couldn’t be established. This means the network is likely restricting the connection, commonly due to firewall settings.
For more information about WebRTC, see this article:
Since all cameras and Apple TVs are on the same LAN and the “speed up remote connection” camera setting is already off, I’d recommend checking the following:
  • Whether the network is blocking or mishandling WebRTC traffic
  • That the following ports are open and accessible:
    -TCP/UDP 3478, TCP 443, and UDP 50000-50200 for direct streaming
    -TCP/UDP 20000-40000 and TCP 8989 for tunneled streaming
  • Whether any security features like advanced firewall, intrusion prevention, or client isolation are enabled on the network.
For more information on port and protocol requirements, see this article:
If you have any questions, please let us know.
Thank you!
