Upgrade the Simon XTi 3G cellular module to the new LTE version. There seems to be no where to install the old daughterboard for the image sensor. I couldn’t figure out how to add the image sensor to the panel as is. Is the image sensor compatible with LTE board?
New LTE modules version X187 and above actually have the image sensor capability built in, no daughterboard needed.
Can’t seem to get it add. Removed and reinstalled the batteries on the image sensor, red light is flashing, but the panel doesn’t pick it up. Any suggestions?
The Image Sensor would need to be reset to forget its prior network connection. Use a paperclip and press and hold the small recessed reset button a full 10 seconds until the sensor LED flashes rapidly to reset the sensor and clear it from its network.
got it to work, Thanks Jason!
Happy to help!
