SMKT3-345
This will need to be programmed in 3 times. Once for smoke detection, once for heat detection and once for freeze detection.
Heat:
Sensor Type: 24 Hour Fire
Equipment Code: (1058) SMKT3-345 2GIG Smoke Detector
Serial Number: Press “shift” then “learn” then tamper the detector by removing its back plate. It will typically take a few moments to register the signal.
Equipment Age: New
Loop Number: (2)
Dialer Delay: Disabled
Sensor Name: Insert vocab using 2GIG codes found here
Reports: Enabled
Supervision: Enabled
Chime: Voice
Freeze:
Sensor Type: 24 Hr Auxiliary
Equipment Type: Freeze
Equipment Age: New
Loop Number: (3)
Reports: Enabled
Chime: Voice
Smoke:
Equipment Age: New
Loop Number: (1)
Reports: Enabled
Chime: Voice
