How to Install an Indoor Fixed w/IR Camera ADC-V521IR and ADC-V522IR
Pre-installation checklist
ADC- V521IR
  • ADC-V521IR camera (included)
  • AC Power adapter (included)
  • Ethernet or Wireless (2.4 GHz) connection to broadband (Cable, DSL, or Fiber Optic) Internet
  • A computer, tablet or smartphone with Wi-Fi is required if the router does not have the Wi-Fi Protected Setup (WPS) feature
  • Login and Password for the Alarm.com account to which you will add the camera
521install
ADC-V522IR
  • ADC-V522IR camera (included)
  • Ethernet or Wireless (2.4 or 5 GHz) connection to broadband (Cable, DSL, or Fiber Optic) Internet
  • Login and password for the Alarm.com account to add the camera to
Add the camera to an Alarm.com account
To add a camera, connect the camera to the wireless network and then enroll the camera to the Alarm.com account. There are three local options for connecting the ADC-V521IR to the network: Ethernet Mode, Wi-Fi Protected Setup (WPS) Mode, and Access Point (AP) Mode. Once the ADC-521IR is added to the account, it can be permanently installed using either a wireless broadband connection or wired Ethernet connection.
Note When the camera is powered up, always allow at least two minutes before pressing any camera buttons. The first time a new video camera is powered up, it automatically goes into AP mode (flashing white) after two minutes.
WPS Mode
AP Mode
Ethernet
LED reference guide
Connection status
  • Sold Green: Internet Connection - Local network and internet connection
  • Flashing Green: Local network connection - Local network connection only, no internet
  • Sold Red: No network connect - No local network or internet connection
  • Flashing Red: System booting - Camera is booting
Wireless enrollment
  • Flashing Blue: WPS Mode- To enter WPS mode, push the WPS button and release when flashing blue (about 3 seconds)
  • Flashing White: AP Mode - To enter AP mode, push the WPS button and release when flashing white (about 6 seconds).
Factory reset
  • Flashing Green and Red: Factory Reset - This will restore factory-default settings to the camera. If already installed, the camera may need to be removed from the Alarm.com account and re-added after a factory reset. To perform a factory reset, push the WPS button and release when flashing Green and Red (about 15 seconds).
Troubleshooting
  • If you have issues connecting the camera to the account, power cycle the camera (unplug the power jack from the camera and then plug it back in to restore power) and try adding the camera again.
  • If issues persist, Factory Reset the camera to defaults by using the WPS button located on the back of the camera.
Factory reset an ADC-V521IR or 522IR
Resetting a device to its factory default settings removes all of its existing programming and memory. Most devices must be removed from the account and re-enrolled after a factory reset
Important Wait at least 2 minutes for the device to power on fully before performing the following procedure. The factory reset might fail if the device is still powering on.
To do so, Press and hold the Reset button until the LED alternates flashing red and green, which usually happens after 10-15 seconds. The Reset button can be found on the back of the camera.
ADC-V521IR ADC-V521_clipped
ADC-V522IR 522
Once a video device has been reset, it is normal for the LED to turn off momentarily. It is best to leave the video device plugged into power and undisturbed for 2 minutes after performing the factory reset.
After being factory reset, the ADC-V522IR reverts to Access Point mode (blinking white LED).
