tyler
(Tyler G)
June 15, 2021, 7:05pm
1
To enroll a camera, connect the camera to the local network, then associate the camera with the Alarm.com account.
There are three local options for connecting video devices to the network:
Ethernet,
Wi-Fi Protected Setup (WPS) Mode, and
Access Point (AP) Mode.
Some video devices can only be connected using some of those options, so verify which methods are supported before beginning the enrollment process.
Pre-enrollment checklist:
AC power adapter (required for non-PoE connections)
Broadband (Cable, DSL or Fiber Optic) internet connection with a router
A computer or mobile device with internet access
An Ethernet/Cat5 cable (if using an Ethernet-capable camera)
Alarm.com account access through the ADC Website, or ADC mobile app.
WPS Mode
Wi-Fi protected setup (WPS) is a computing standard protocol that allows for the easy set up of secure wireless home networks. It allows devices to be easily added to a secure home wireless network without having to manually enter a password.
Note: WPS can be used any time, even if the camera is still mounted and the customer gets a new router. WPS can always be used to initiate a wireless connection between the camera and the router.
WPS installation steps
Power up the video camera:
Conn…
APS Mode
AP Mode
Access Point (AP) mode allows for devices to be added to a secure home wireless network by connecting to the camera’s temporary access point using a Wi-Fi enabled device.
AP mode installation steps
Activate AP mode on the camera:
Connect the camera’s AC adapter and plug it into a non-switched outlet. The camera’s LED illuminates red while it is booting up.
Wait for the camera to finish its startup process. This should take approximately 2 minutes for most Alarm.com video cameras.
Press…
Ethernet
Some Alarm.com video devices have the ability to use an Ethernet cable for an Internet connection.
Plug an Ethernet cable into the video device and the local router or networking device.
Connect the camera’s AC power adapter and plug it into a non-switched outlet. If the video device is using Power-over-Ethernet, ignore this step.
When the LED is solid green, the wired connection is complete. If the LED is not solid green after a few minutes:
A. Power cycle the camera.
B. Try a different Eth…
Enroll the video device to the Alarm.com account
Once the video device is connected to an internet network, it can be associated to a Alarm.com account using the Alarm.com mobile app or Alarm.com Website.
To enroll the video device using the Alarm.com mobile app installation wizard:
Log into the ADC mobile app.
Tap **Menu
Tap Video .
Tap Settings
Tap Add Video Device .
Tap Install for the desired video device to be installed.
Follow the on-screen prompts for installing the video device.
To enroll the video device using the Alarm.com Website:
Log into the Alarm.com Website.
Click Video .
Click Settings .
Click Add Video Device .
Find the desired video device in the list and enter a name for the video device.
Next to the desired video device, click Install . The video device appears in the list automatically when it is on the same local network as the device performing the installation. If the video device is missing from the list:
Enter the MAC address found on the video device’s label, and then click Find .
Note : For the 2GIG HD100, use its ETH MAC address.
In the device name field, enter a name for the video device.
Click Install .
After the device is successfully installed, the camera settings are configurable using the Alarm.com Website. If the video device needs a Wi-Fi connection but was installed using an Ethernet cable, the video device’s Wi-Fi settings need to be configured through the Video tab.
Power down the video device, and install it in its final location using the included hardware.
tyler
(Tyler G)
June 15, 2021, 7:47pm
5
Device Specific Guides
ADC-V523/523X
LED reference guide
LED pattern
Description
Off
Power off
Solid green
Connected to Alarm.com
Blinking green
Local network connection
Blinking red and green
Camera resetting to factory default
Solid red
No local or Internet connection
Blinking red
Power on, camera booting
Blinking blue
WPS mode
Blinking white
Wi-Fi access point mode
Troubleshooting
If you have issues connecting the camera to the account, power cycle the camera and try again.
If issues persist, Factor…
ADC-V723
1080p Outdoor Wi-Fi Camera (ADC-V723)
[Data_sheet_V723_image]
Pre-installation checklist
ADC-V723 camera (included).
AC power adapter (included).
Wireless (2.4 or 5 GHz) connection to broadband (Cable, DSL, or Fiber Optic) internet.
A computer, tablet, or smartphone with Wi-Fi is required if the router does not have the Wi-Fi Protected Setup (WPS) feature.
There are two options for connecting the V723 to the Wi-Fi network: Access Point (AP) mode or Wi-Fi Protected Setup (WPS) mode. Use WPS…
ADC-724 / 724X
[ADC-V724]
In the box
ADC-V724/724X camera
Power adapter
Wall anchors & screws (3)
Installation guide
ADC-V724/724X camera (included)
Wi-Fi (2.4 or 5 GHz) connection to broadband Internet(Cable, DSL, or Fiber Optic) Internet.
There are two options for connecting the V724 to the Wi-Fi network:
Access Point (AP) m…
ADC-622
ADC-V622 camera (included)
AC power adapter (included, required for non-PoE connections)
Broadband (Cable, DSL, or Fiber Optic) Internet connection
[ADC-V622_back_of_camera] [Overview_V723]
Add the camera to an Alarm.com account
To add a camera, connect the camera to the customer’s wireless network and then enroll the camera to the Alarm.…
ADC-V826
[vc826]
Pre-setup checklist
ADC-VC826 camera
AC/DC power adapter (required for non-PoE connections)
Broadband (Cable, DSL or Fiber Optic Internet connection with router)
A computer or mobile device with Internet access
An Ethernet / Cat5 cable
Login and Password for the Alarm.com account to which you will add the camera
Complete these steps prior to installing the camera in its final location.
Connect the camera to the router via an Ethernet cable.
SkyBell HD and Slim (VDB101, 102, 105, 105x, 106, and 106x)
Can the SkyBell Doorbell Camera be used without a chime?
Yes. However, the power requirements are different when installing a SkyBell Doorbell Camera without a chime. The SkyBell Doorbell Camera will either require a 10 Ohm 10 Watt resistor with 5% tolerance on the existing AC transformer’s circuit or a DC adapter rated at 12 VDC 0.5–1.0 Amps.
Installing a SkyBell Doorbell Camera without a chime is typically done for testing or demonstration. It is recommended to install the SkyBell Doorbell C…
This guide will walk you through how to pair a SkyBell Slim or SkyBell HD video doorbell to an Alarm.com account. This guide does not cover how to physically install the doorbell and presumes this step has already been done.
The use of the SkyBell Video Doorbell does require video to be enabled on your account.
When using service through Surety, video is included in the Surety Cam/Plus, Protect, and Complete plans. Video levels can be added/increased via the System Manager page of your Surety…
ADC VDB770 Video Doorbell
Connect the ADC-VDB770 to the network
AP Mode (recommended)
The camera is in Access Point (AP) mode when the button LED is blinking white. If necessary, access AP mode by holding down the doorbell button for 35-40s and release when the LED turns to blinking white.
Using a Wi-Fi-capable device (e.g., smartphone or computer), find and connect to the camera’s network; the SSID should have the format ADC-VDB770 (XX:YY:ZZ) where XX:YY:ZZ is the last 6 characters of the MAC address, which is prin…
ADC VDB780B
Use this guide to assist with the installation of your ADC-VDB780B Wireless Video Doorbell.
[ADC-W115C_Data_Sheet] [VDB780_Data_Sheet_Render]
In the box
ADC-VDB780B mounting plate
10º tilt wedge
Battery pack
Charging cable
Mounting screws (2)
Mounting anchors (2)
Wedge screws (4)
Quick start guide
Important: A service package that includes Video Analytics and the Doorbell Cameras add-on is required to enroll the ADC-VDB780B.
ADC VDB750
[VDB750_hero1v3]
Features
Expansive 165° horizontal and 145° vertical Field of View ensures customers get a full picture of what’s happening at their front door
Video Analytics with rapid People Detection for faster, more relevant alerts and fewer false notifications
Full HD resolution, High Dynamic Range (HDR), and infrared night vision
Two-Way Audio
Compatible with the Alarm.com Smart Chime (W115C)
2MP live video and saved clip viewing via the app and customer website
Dual antenna (2x2 MIMO…
ADC V726 Indoor/Outdoor Mini Bullet Cam
Troubleshooting
If issues persist, reset the camera to factory defaults by following these steps:
Remove power from the device.
Use the hex key that comes with the ADC-VC726 to remove the water-tight door on the bottom of the camera to reveal the reset button.
Press and hold the [Reset] button while reconnecting power.
After reconnecting power, continue to hold the [Reset] button for 10 seconds.
A…
ADC Indoor Fixed PanTilt ADC-V620PT
Required items for installation:
ADC-V620PT camera and power adapter (included)
Broadband (Cable, DSL, or Fiber Optic) Internet connection with a router.
Computer or web-enabled device
Username and password for the Alarm.com account
A router with a Wi-Fi Protected Setup (WPS) button or an Ethernet cable
If the router does not have a WPS button, and the camera will be connected to a wireless network, you will need the case-sensitive SSID (wireless network name) and the network WEP or WPA key (…
Indoor Fixed w/IR Camera ADC-V521IR
ADC- V521IR
ADC-V521IR camera (included)
AC Power adapter (included)
Ethernet or Wireless (2.4 GHz) connection to broadband (Cable, DSL, or Fiber Optic) Internet
A computer, tablet or smartphone with Wi-Fi is required if the router does not have the Wi-Fi Protected Setup (WPS) feature
[521install]
ADC-V522IR
ADC-V522IR camera (included)
Ethernet or Wireless (…
Indoor/Outdoor Dome (ADC-VC825)
The ADC-VC825 from Alarm.com is a high-performance fixed dome camera optimized for indoor and outdoor video monitoring. Its discreet, compact design and outstanding HD quality video make the camera ideal for both commercial and residential video installations. The camera features a vandal-resistant exterior casing with an IP66 rating and Power over Ethernet (PoE) capabilities.
[825body]
1080p Indoor Wi-Fi Camera ADC-V515
ADC-V515 camera (included).
2.4 GHz Wi-Fi connection to broadband internet (Cable, DSL, or Fiber Optic).
An Alarm.com account with a service package that supports video.
There are two options for connecting the ADC-V515 to the Internet: Access Point (AP) mode and Wi-Fi Protected Setup (WPS) mode. Use WPS mode if …
