I manually tampered all of my sensors (had to re-learn the sensors), however I can’t clear the “tampered” status now - they all show up and communicate correctly but won’t go back to active.
Any advice?
Any advice?
Putting the cover back on should un-tamper them. I’m not sure what kind of sensors you have but in most sensors there’s a physical tamper switch that gets closed by the cover/housing when it’s put together correctly. I assume you put the covers back on all the sensors? Which sensors are you working with?
