Heat Detector Garage - Ideal Location
Yes, the PG9945 should learn in as normally open EOL and does require the end of line resistor that is provided with the sensor. This has changed on the latest panel update as before it was only programmed as normally open and you wouldn’t need the end of line on the heat.
