Hello, I’m interested in purchasing the Hardwire 16 to use with my current new frontpoint/Qolsys IQ with my older Brinks Hardwire led sensors. I would like to purchase this from you, but I’m not 100% sure it will work. Can you shed some light on this? Also if I try one sensor and it doesn’t work, can I send the unit back for a refund of some sort?
The RFPIC version of the Qolsys panel will need to be 7 or higher for functionality. This would come into play if you receive an older panel, but a new one should be fine.
You can find our returns policy here.
Thanks for the info. I placed the order for the items I need. Hopefully the install will be easy!
Not too tough.
Been running a hardwire 16 for a couple months now and it’s been solid except for one problem early on where the hardwire 16 unit itself went into error state on my IQ panel. Qolsys support suggested removing and re-registering it (this didn’t effect the hardwire sensors I had registered) and leaving a permanent wire in on the tamper after registering it. I haven’t had another problem since.
Good to know it’s working well. I can’t wait to get it all installed. Hopefully it will ship soon. I ordered it yesterday.
Alright folks, ran into a little problem this afternoon.
Everything seemed to be working great with the Hardwire 16. Then suddenly this morning the IQ panel set off a fire alarm randomly. It was armed in stay mode. After disarming it, I now have an alert item that say “Hardwire translator” type “tampered”
Under the Hardwire translator the status says “tampered”
The sensors seems to be working ok(the doors atleast)
This brings me to another question. When you guys install the Hardwire 16 and have to trip the sensors to register it, how do you trip the smoke alarm and the glass breakers? I’m wondering if I did something wrong.
Thanks ahead of time for the help!
From an earlier post in the thread:
It sounds like a jumper can be placed between the tamper terminal inputs. Just a short length of wire would do.
The IQ Hardwire 16 is not designed for use with life-safety device circuits, like smoke detectors. Unlike the 2GIG Take-345, the Hardwire 16 can accommodate NO (normally open) circuits, but the instructions state not to use with smoke detectors.
Existing low voltage smoke detectors would need to be replaced with wireless versions.
Guess I missed that about the smoke detectors. I will take those sensors out. How about the glass breakers. How do you trip those to have it recognized by the Hardwire 16.
Is there some way to test that these are actually working!?
Glass Break detectors can be difficult to test, though it depends on the model. There are some forum threads dedicated to options for testing glass break detectors.
There are dedicated testing devices that professional installers will use. However, models that are more sensitive can often be tested with jingling keys, other models may require a sound file of glass shattering along with a thump sound, if you have a laptop with good speakers it’s pretty easy to find a sound file of shattering glass to try.
Do you know the model number of the Glass Break detectors you are adding? Are they all the same model?
I don’t know what model my glass breakers are. They were installed by brink home security about 7 years ago. I need to get upto one and see if I can find any info.
Tell me if this works: when I was registering the sensors on the IQ panel, for the glass breakers, I just tripped them by disconnecting one of the leads at the Hardwire 16 and this tripped the sensor, and it showed up on the IQ panel. I’m just worried that they won’t actually work since I never actually tripped them. (I have 4 btw, and they are wired in series).
I have uninstalled and reinstalled the Hardwire16 and placed the jumper in the tamper terminal, and also disconnected the smoke detectors. I did purchase a “smoke alarm audio detector” from suretydiy, so I’ll install that to tie my smoke detectors to my Qolsys.
Keep in mind the ECFF319 (the Audio Detector) is for High Voltage interconnected Smoke detectors. Quite often, low voltage wired detectors do not have a local sounder, instead relying on the Alarm system sirens for audio alert. You would want to verify this. What model of smoke detector do you have, and are they all the same?
For the glass breaks, tripping the circuit by removing a wire physically acts upon the circuit the same way that setting off the sensor would, so yes, that would work fine to learn them in.
I would still recommend testing them to make sure they are functioning properly, even more important since they are older. If you can get the model number of the glass break we may be able to help with the general level of sensitivity and what is likely required to set them off reliably.
Good news, the audio detector worked great! I did a test on the smoke detectors and the IQ picked it up just fine.
I will try and do a glass break test. Need to do some research and find the right audio file and speaker setup.
Best way to test glass breaks is by breaking glass. Go to dollar store, get a few $1 glasses, and any box will do (even a free USPS medium flat rate box), Then go near a door/window to simulate it breaking, and with a hammer start smashing the glass in the box (be sure to tape the seams before hand)…wear eye protection.
You also need to properly test a smoke detector with canned smoke, Using test button wont actually tell you if smoke alarm/detector functions. Canned test smoke runs $10 online.
testing a smoke detector with canned smoke aerosol:
Good info. Will try the glass breaking trick, and I’m gonna order that canned smoke!
Thanks!
