jnusaira
(Joseph)
April 30, 2015, 8:31pm
1
I purchased the GoBridge Communicator.
I am going through the install and question 7 says:
At the enter question number screen, enter 92
At Q92 Select Network Device
… however i don’t see a question 92 when i go through and i scroll through the others an there was no “network device”
oh and an aside my Communicator came programmed with Daylight savings turned on … remember we don’t have that in Arizona
rive
(riven)
April 30, 2015, 9:31pm
2
(Q)uestion 92 (as well as Q93-Q95) were added in firmware 1.12, If you don’t see it, suggest you update your firmware version.
For accessing programming Q’s (questions), see:
http://www.2gigforum.com/threads/5-2GIG-Installation-Programming-manuals-and-optimal-panel-settings
Daylight savings time setting: Q66(0)
The time is set via alarm.com
The cellular module determines the time and overrides any panel setting for time/date/DST. It has to be adjusted on ADC backend.
The above is correct. You will need firmware 1.12 or higher to use the Go!Bridge.
The latest firmware (1.13) is available here.
