Has Nortek published the number of Image Sensors the GC3 will support? Right now, I can only use two of my three Image Sensors on the GC2 after adding the Go Bridge (not necessary for the GC3) which must have been an oversight on firmware 1.12 (and 1.13) since the 900 MHz transceiver supports 3 Image Sensors (2 with Go Bridge) and 4 TS1s (of which I’m only using 1).
Not at this time. I suspect we will have to wait until it is officially launched for firm information regarding what it supports and other specifics for the GC3.
This has already been discussed to death, (trust me), and it is not an oversight. It is by design.
900mhz transceiver supports:
3 Image sensors (or 2 with bridge, since the bridge uses a IS “slot”)
The panel itself only supports 4 keypads or 4 TS1’s (or combination thereof)
The 900mhz devices limit cannot be mixed… you can have up to 4 TS1 slots (less if you have any PAD1’s), and up to 3 IS slots.
