ADC has two skills. One to allow Echo to work with ADC. This skill works fine
The 2nd skill is called ADC Smart home that allows you not not not have to say “tell ADC to…” Before the command
After enabling 2FA the Smart home skill doesn’t work. After disabling it and re enabling it, it won’t link. On the echo skills review page, other users indicated this as an issue as well
That is correct, Alarm.com cannot do the 2FA authorization on the Smart Home Skill, so it is recommended if you want to enable the smart home skill which is just for automation, to create a new Alarm.com login without 2FA with only access to thermostats and lights. This will get around that limitation.
