Hello - just moved to Surety from another provider, same cameras SVR setup etc. I have 8 Cameras installed and a QOLSYS 4 panel. I cannot add my panel bc the maximum number of devices are registered - with 8 cameras an the SVR. I am confused bc I had the same add on service with my last provider that allowed the 8 cameras and the panel (cannot recall if the SVR was showing up then).
Should the SVR be added or not? And if so why is it I am not able to add the panel this time round.
The SVR uses a separate pool of SVR devices. It does not count as a camera.
The IQ Panel 4, if you turn on video for it, Alarm.com counts it as a video camera device toward your total. If you had the panel enabled previously with 8 cameras, that would mean that your prior service was set up to support more than 8 cameras.
To add 8 video cameras and the panel video, you would need an extra level of video support. You can add support for additional cameras at any time in our system manager here.
