Converting from existing Brinks system to Surety. Can I use existing hardware?
The sensors themselves, no. They just broadcast a signal and the panel needs to be programmed to listen to it. Steps to program 319.5Mhz sensors into an IQ Panel 4 are in the link below:
If you have any Z-wave automation devices, many lock models have a local programming code. You may need to factory reset the lock to gain access to its code if you have one.
