Check Sump Pump Remotely
Can I use a wireless sensors to monitor my sump pump? I’d really like to check on this remotely when I’m away for extended periods.
Are you opposed to using a water bug style sensor and just detecting when water rises to the floor next to the sump pump?
http://resolutionproducts.com/products/compatible-sensors/re-ge-elk-compatible-home-disaster-sensor-2/
It’s not nearly as MacGyver as some options, but it’s easy to set up and won’t wake you up in the middle of the night unless there’s a real problem.
