Cat5E as low voltage for 2GIG panel
Can I use cat5E as the low voltage wiring to power my 2gig panel? I tested it and it works but I don’t want to create a fire hazard. Thanks!
You should be fine using cat5E as low voltage for your panel. I would double up on the conductors just to make sure you don’t have any voltage drop, but cat5E should be fine to use as low voltage wire.
Thank you Jay for the quick response!
