I have two rules setup to lock my doors. Arm stay (no delay) works perfectly, every time. Arm away is set to lock after 1 minute. It never works at all.
Ive tried recreating the rule, no luck. Any guesses?
Happy to help! How are you testing the rule activation?
Note that it looks like Auto Stay is enabled in your panel settings, which means if you arm the panel Away at the panel screen and do not open an Entry/Exit door during the countdown, the panel will revert to Stay arming, and the away rule wouldn’t trigger.
If you are instead arming away from mobile or website and one rule works and the other doesn’t, try testing the differences between them. Largely it looks like just the delay before activation of the lock. Can you try changing that to happen immediately just to test? Any change?
