Generally speaking, when we do a full service installation, we drill or cut a hole in the wall behind the panel and put the antenna in there. The antenna can stay inside the panel if necessary, but you may run into an issue where there is some signal interference.
Keypads and Image sensors will automatically trigger during a walk test without any prompting.
