Alarm sensors malfunctioning
I have some sensors malfunctioning and wondering if alarm would go off for a malfunctioning sensor
It depends on the malfunction but looking at your system, they are restoring and then malfunctioning again. It can cause an alarm while the system is armed.
What are the troubles showing up on the main panel? If they are supervisory troubles, check the back of the panel for a white antenna. This should not be coiled in the back of the panel and should lead to the back of the wall.
