Alarm is not going off and it is not sounding when the door is opened. The Alarm stays as Armed stay.
Is this a new sensor, or an existing sensor? If the later, when did it stop activating? What model sensor are you using?
It doesn’t look like there are any sensors currently programmed into your 2GIG panel. You would need to add the sensors to you panel before it will respond to them. Do you have any questions about how to do that? This video is a good start.
To access panel setting configuration:
Screen Logo>enter installer code>system configuration
Right arrow to blank sensor location, then down arrow
Two ways to enter serial:
- Manually enter it: or
- shift, then learn. Pull magnet from sensor (or if installed open door/window)
Program DW10
(01) entry delay[door] or (03) perimeter[window]
(0862) dw10
serial
(0) new equip
Loop (2) 2
(0) disable dialer delay
Voice descriptor codes
(1) report enabled
(1) supervised enabled
(01) voice only
Skip
End
Exit
Program DW20R
*(01) entry delay 1 or (02) Entry delay 2
(0863) dw20r
serial
(0) new equip
Loop (1) 1
(1) report enabled
(01) voice only
Skip
End
Exit
*(01) 30 sec; (02) 45 seconds (exit and entry delays are Q5, Q6, Q7)
It looks like sensors stopped reporting activity and were removed from the system 1/22/2016. Were you or someone else working on the system? It looks like sensor tests were performed, a manual phone test, and sensors were deleted.
